I’m making a left-arm-only European 4-in-1 mail sleeve and I’m stuck at the elbow.
It’s for a costume/festival project, not combat. I’m using 18ga 3/16" ID anodized aluminum rings, with some black EPDM rubber rings for the inner forearm closure. I’m going for a fairly form-fitted “Winter Soldier” style arm, so I’m trying to avoid just making one big loose tube.
I have two separate sections mostly finished:
Forearm section:
Do I need some kind of 45-degree seam? 90-degree seam? Diamond/rhombus gusset? Extended upper arm? Extended lower arm? Elbow pocket? Some totally obvious mail-sleeve thing I’m missing?
I keep finding references to historical elbow shapes, but not much actual “here’s how you connect the pieces” guidance. I’m open to practical/non-historical solutions since this is just a one-arm costume build, and I don’t necessarily need a full hauberk-style armpit/body attachment.
Any practical advice, diagrams, examples, free tutorials, or videos would be hugely appreciated. Preferably free resources, because I’m a broke student and already bought one PDF that was more theory than how-to.
This elbow section is melting my brain.
Forearm section:
- tapered lower-arm tube
- closes on the inner forearm with rubber rings
- the elbow-side end is basically 55 rings around
- separate bicep/upper-arm tube
- starts at 55 rings, expands up to 69 rings, then contracts down to 63 rings over 18 rows
- the lower end that needs to connect to the forearm is also basically 55 rings around
